Thread: Need Advice
Old Jan 1, 2019 | 10:05 AM
amx1397
Default Re: Need Advice
Originally Posted by amx1397
is it coming from front or rear? does it happen when you take off from dead stop? does it happen you give it wot( wide open throttle) or a hard (fast take off)? ok,,,,,, it is either the center bearing on the drive shaft ,,or it is the drive shaft.,if it is when going over a bump then it is the sway bar. jim
from what u said about feeling the e brake the do this after it is warm,, and all quite , take off hard, if it is there it is the center bearing or the u joint on the driveshaft. jim
