Old Jan 5, 2019 | 02:32 PM
onehundred80
Default Re: Water pump gasket advise please.
Originally Posted by Tom3120
So I have the water pump off of my car. I have a new GMB water pump that came with gaskets. I guess I didn't look at them close enough before I started because I thought it was a flat material type gasket which is what the oem pump had on it that I removed. The new GMB pump has a metal frame and a rubber seal. Is this a good seal to use? Ive obviously never replaced a water pump before but I've never used a gasket like this before either. Is this a new and better type?
I looked around on Google for answers, one person was complaining that they had to put gasket.cement on one face, with the rubber on the other face, if this is true I would not like that idea at all, that means there are two faces to leak. Look on Google and study their catalog, it may have the answer you need.
