Re: Banging noise
[QUOTE=NeedsWings;917557 sounds like the driveshaft center support/bearing. we have them on the drivetrain page on our website. very common wear item for these cars.[/QUOTE]
Rob is most likely correct,, but don't buy one off ebay they are crap. get the correct one from Needswings
takes about 20 to 60 min to replace make sure you reinstall the two halves of the driveshaft back with the notches in line (for balance.) on one half you will see two notches on the other you will see one they must be centered to each other jim
