Thread: Stuck relay
Old Jan 14, 2019 | 02:34 PM
tripley's Avatar
tripley
Default Re: Stuck relay
It’s drawing .01 amps across the meter, probably the four way flashers which are blinking. When I recharge the battery, I can get it to run momentarily three times. At that point the battery needs to be recharged. It seems to make little difference on the power draw if the key is turned on or off. I don’t have the sort of meter that will take the full amperage of starting. The starting three times is pretty predictable, I was thinking I might have a skreem issue, but for the battery being discharged. Any ideas?
