Rear Sway bar brackets cracking
69
permalink
01-15-2019, 08:04 AM
zip439
Re: Rear Sway bar brackets cracking
under coating completed
inside looking outboard
stabilizer/sway bar installed
Completed the sway bar installation and reinforcement. I used Rust-Oleum undercoating which dries hard and can be painted not the asphalt type that remains soft. In the inside view you can see where I welded the two new metal brackets together so the 1/4 inch piece can not slide rearward. I used a little silicone grease in the bracket bushing. The bushings come with the new H & R sway bar.
I couldn't find the two sway bars as a kit here in the states. However I know see tirerack does carry both bars. I bought from the "tunershop.com" online and they were shipped from Germany. I was told from ESC tuning that the H & R cup kit is no longer available, but I was able to purchase from the tunershop and again it shipped from Germany. The stabilizer bar and springs are H & R blue, shocks are black with a H & R decal. The shocks are gas, not gas/oil and look just like the OEM with the upper shield and bump already installed. They also come with the upper mounting rubber pieces for installation.
Like
zip439
View Public Profile
Send a private message to zip439
Find all posts by zip439
