Re: Fog Lights Just Quit Working
Check the fuse and if it is OK check for power at the fuse upstream terminal if the fuse is OK it will tell you which side of the fused wire has the problem, no power at the fuse then the trouble lies upstream of the fuse. Power at the fuse means the trouble lies downstream.
