amx1397
. the spacer is 15mm thick so the inside is cut in 66.6 and the outside is 66.6 so you can run stock wheels yet keep the hub centric the same inside and out so to keep your stock wheel straight,
You did not say yours to were 15mm thick, at 5mm thick it is not possible.
