Old Jan 23, 2019 | 04:58 PM
  #107 (permalink)
Centaurv's Avatar
Centaurv
Default Re: Let's discuss the key fob transponder chip(s)
I found sometime ago the Following on this site. I can't remember where but here it is :Trucs pour CrossfireThis is straight from the Crossfire manuals supplied to the dealership, or if you are a Chrysler tech, I got it from Tech Connect.
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100 or more.
