Thread: Losing power
Old Jan 27, 2019 | 04:01 PM
dinasrt's Avatar
dinasrt
Default Re: Losing power
Originally Posted by Peteroses1975
I just checked my fuel pressure it's 60 PSI and it maintains 60 PSI even when I mash the throttle the car has black **** in the tailpipe and on the bumper and it loses power once it warms up I was trying to start with the fuel pressure regulator but cannot locate it any suggestions or pictures
The fuel pressure reg. is integrated into the fuel filter at the rgt. rear under cover next to the differential. Use the forum search at the top. I'd be certain your "upgraded" coolant pump is actually working properly first. But it does sound like you may have a Rich fuel ratio happening. "Black ****" in the pipe is normal, but shouldn't be so bad as to soot the bumper I would think. Stock fuel pressure is typically 58 p.s.i.
