Driver's side window doesn't go up
Has anyone figured out how to fix the driver's side window? It works intermittently, so normally I just don't use it. However, a body shop convinced me that they could fix it and it still only works intermittently. A new motor was bought...that wasn't it. The switch was put on the passenger side and worked...so that's not it. They said they found a loose wire, but then it only worked for a day until I opened it up this morning in the freezing cold and it wouldn't go back up. (Window always goes down....problem is that it will only go back up intermittently. It worked for a year...and then the last year it started the intermittent thing again.)
Any ideas will be greatly appreciated.
