blankenshipl09
I definitely did not put my key through the washer. Also, I have 3 of them and have tried each with the same results.
Since my last post I’ve replaced the rcm and still got the same symptoms. I also tested the MAF sensor and then installed a new one just to be sure. That didn’t make any difference either. I still have the same symptoms.
Anyone have any other ideas?
I am glad you checked all of the keys. This does have the classic symptoms of bad SKREEM. Since PIZZAGUY knows the entire start sequence we might need a refresher. Pure logic and process of elimination still come back to the SKREEM. Here is why;
the third try and no crank. If this were some other component the SKREEM would register the key as good and continue to let the car try to start but since it is disabling the further attempts you have to look at all the SKREEM does to prove it has the correct key and
is able to tell the rest of the starting process to continue past the 3 tries. IE, bad CPS still allows the user to crank and crank and crank as many times as needed but no CPS signal no start. No fuel pressure no start but cranks like mad. Etc. Etc.
The 3 tries and done point TO the SKREEM.
Did you perhaps swap the key antenna for the FOB unlock/lock antenna at the SKREEM? Not even sure if that is possible with connector types.
Does your trunk have water around the locking module? It may tell the SKREEM there is a fault kick the user from starting.
Rodents in the car? That will do weird stuff!
I am certain this is the SKREEM telling the car to stop the starting process but it's some external component telling it to. (like swapped antennas)
