Re: Pulse module NOT sending signal
Pizzaguy,
Have you seen my replies to your questions in the thread 'RCM' as you requested ?
Also, the only connection between the PM and ECM(PCM)is the Pink/Red wire from terminal 2A. It is marked 'sensor ground' which seems to be the mis-labelled connection ?
Mick
