Old Feb 4, 2019 | 12:26 PM
onehundred80
Default Re: bigger axles for everyone
Originally Posted by amx1397
you bring up a good point, so i just weighted them, both weight 17 lbs ea. now i have to cut one to be sure,, i know the srt 6 axle is solid. because i broke one ,years ago, if the larger one was solid it would have to weight more,than the smaller one. , I think Chrysler put out a bid for axles and the co. got the bid and made solid axles,, then on the next bid the co. that got the bid made the hollow ones ,both the same weight but the hollow one are 44.4% stronger
so yes same weight ,it has to be hollow and also is stronger thanks for your input.
Strength to weight ratio for hollow shaft is 44.4 % higher than Strength to weight ratio for solid shafts2.
Strength to weight ratio is better for a hollow pipe than a solid rod." This means a hollow cylinder is stronger than a rod of equal mass and the same material. A hollow cylinder with a bigger inside diameter is better. In the limit x → 1 the hollow cylinder is twice as strong.Jul 29, 2011
This is a bit simplistic, what kind of strength are you talking about ?
What has Jul 29. 2011 got to do with it.
Mercedes would have put out the bids not Chrysler.
