Old Feb 4, 2019 | 03:09 PM
colink's Avatar
colink
Default Re: 2004 Cranks, starts and dies. It's not the SKREEM. Help Please!!
Is the fuel pressure maintained after the relay opens?
The fuel filter has a check valve which is supposed to maintain the pressure between the time the relay opens and the engine starts. If its bad the pressure will drop off, the engine will not run and the filter needs to be replaced. Turn the ignition on and confirm the fuel pressure is maintained after the initial build up and before the starter is engaged.
