Old Feb 7, 2019 | 06:59 AM
onehundred80
Default Re: Rain Water Leak...What I did about it.
Originally Posted by skroadster
Thanks. Are they connected to hoses? Blow them out and/or slide a coat hanger wire through to clean?
The blockage is normally over the drain hole and maybe slightly down the drain hole. You do not want to force the jam tighter and further down the pipe. Look and see what your situation is. You can see the end drains behind the rubber combs.
