Old Feb 8, 2019 | 08:31 PM
John&Terry's Avatar
John&Terry
Default Re: Key fob stopped working
Sliding a strip of thin cardboard or stiff paper down the edge of the foam at the forward edge works well and takes no effort, removing the foam in the coupe means removing the roof panels and putting them back is not fun at all.
Thank you. I will try this as a quick check. Also, I will have to remove the roof panels anyway, if the pump assembly needs to be replaced. So I would rather do it before that happens. I appreciate everyone's advise.
