Old Feb 11, 2019 | 04:12 PM
  #85 (permalink)
onehundred80
Default Re: steering / ignition locking
Originally Posted by bobpatterson
I have an 05 with a Sterring Wheel lock issue - unable to start - can only push it straight.
My shop determined it was a sterring weel lock issue - the parts don't seem to be available from Chrysler - can Mercedes parts be used - what would the part number be?
One person spoke about using a file to cut off the steering wheel lock from the ignition assembly - is this a good fix? - and do you have any pictures of this fix?
Thanks!
This is a fix that can be done for no cost, it involves a little work but is 100% effective. ‘Look for Sticky Ignition Fix’using the search function. It is a common fault and should be done as a precautionary measure by everyone. The fix does not cause any problems and the car is just as unstealable. One part is taken out and left out.
The method on how to do it is spelt out in this PDF. CLICK
