Old Feb 17, 2019 | 08:12 PM
tighed1's Avatar
tighed1
Default Re: 2005 no start, turns over great - not fuel delivery
Can you hear the fuel pump run for 2 seconds when you turn the key to the ON position?
or
Check fuel pressure at the fuel rail. Anything?
or
Spray starting fluid into the throttle body and see if it runs while you are spraying.
or
Open the RCM and check to see if the fuel relay is closing for 2 seconds when the key is turned to the ON position.
What code did you get?
