Re: Convertible Rear Window Fix Kit
Nexxus
I am working on a frame kit system to repair the problem of the glue issue on the rear convertible windows. This kit, once complete, will only take about 15 minutes to fix the rear window issue and does not require removing or replacing the convertible top.
I expect each kit to cost between 150 to 200 each.
Before we start creating a test kit I wanted to reach out and see how many people would be interested in such a fix kit?
Thanks in advance. Respond to this tread if you are interested.
I am very interested in hearing about what sparked this idea for you? Whatever it was, it must have worked on some level or you wouldn't have gone as far as you did. I just need some info on how to fix this window because I can't afford a new top! please call me at 949-891-3990 thank you so much!
