Old Feb 21, 2019 | 07:08 AM
BadSRT2005's Avatar
BadSRT2005
Default Re: need advice, please, on Mandrus Millenium wheels
I have mandrus millennium wheels
18x8.5 front with 32mm offset 5x112 bolt pattern
19x9.5 rear with 25mm offset 5x112 bolt pattern
235 40 18 tires on front
275 35 19 tires on rear
No spacers used on front or back
No rubbing
You WILL need 60° cone taper seat lug bolts for those wheels as the factory wheels use a ball seat lug bolts which will NOT fit mandrus wheels
23mm length 60° cone seat lug bolts for the rear ( need to be shorter so as not to interfere with parking brake cables) need 10 of them
28mm length 60° cone seat lug bolts for the front, need 10 of them
