Old Feb 21, 2019 | 09:31 AM
freddyL's Avatar
freddyL
Default Re: need advice, please, on Mandrus Millenium wheels
I have the same set up as BADSRT with the exception of the front offset.because these wheels are not available in 7.5 (our standard size) you have to go with 8.5.I ordered the 43mm offset thinking I could keep the spacing of the wheel the same as stock.I had to use a 10mm spacer because of a clearance issue.going up one tire size from 225/40-18 to 235/40-18 no rubbing.
