Old Feb 24, 2019 | 06:32 PM
Jim Holian's Avatar
Jim Holian
Default Re: Driver side headlight lens (damaged housing okay)
Originally Posted by RyanB
I know it is probably blasphemy to suggest, has anyone tried to retrofit a Chrysler 300c headlight assembly into the Crossfire? Their dimensions appear to be similar. I bet the angles are different - and obviously the mounting hardware, but if it lined up with the body I bet it wouldn't look too bad.
2005 2010 Chrysler 300C "SRT Style" Black Projector Headlights Assembly LH RH | eBay
WOW! Ryan I hope you are right. The headlight assembly for the 300C is quite a bit cheaper. Let us know if that will work.
Jim
