Old Feb 25, 2019 | 02:56 PM
Rajunz's Avatar
Rajunz
Default Re: SRT 6 Supercharger
Originally Posted by philosophico
When you say cut off what do you mean? Is it the hard cut off where it feels like the car has no power when you give it gas which is the blower clutch disengaging the pulley completely due it being too hot, or the random kill when it feels like it goes out for a second and comes back on?
Thanks for looking philosophico.
Meaning, the Supercharger kept disengaging. I figured out my problem this weekend. When I installed the new IC Pump is when I also wired the system for the "Pump Always On" mod. I started going back through all of that and found that the terminal connector on the fuse box end had worked itself loose. After fixing the connector I took it for a ride and my intake temperatures read 85 degrees and stayed there instead of climbing to 185 degrees, which tells me the pump was not running at all. Now she rips and keeps on ripping like she's supposed too.
