Old Feb 28, 2019 | 04:49 PM
onehundred80
Default Re: RH Fog light with broken lens and good internals
Originally Posted by amx1397
100 You are 50%% right on this one, i just looked at it, by removing the adi screw and reinstalling it 1 1/2" from the mounting lug or changing it from 5 o-clock to 7 o-clock it becomes a right hand. the hose remains where it is ,,,but yes 100 it can be a left or right
the only thing that is left and right is the the mounting housing which has a chrysler emblem stamped on it
take a close look.
It can be relocated, take it off, rotate it 180° so the open end is on the opposite side and bend it down and relocate it on the snap that is on the opposite side to the one it has just been removed from.
The rubber may need to be heated as it has taken a set after being in one position so long. When you remove the hose it straightens out about 50% so it was not molded in the shape it sits in. When new it could be bent either way, why increase production costs with a left and right hand part when one straight part would work.
Mounting housing? I state the the housing is the only part which is handed for obvious reasons.
