Old Feb 28, 2019 | 05:11 PM
amx1397
Default Re: RH Fog light with broken lens and good internals
the hose is not in the way. if you move the adj screw you don't have to re bend/heat /remove/ or anything to the hose. YOU do not have to touch the hose. Out of 4 crossfires we looked at within the last hour, 3 were hose on left and right 1 was both hoses were on the right (same side) so some one already moved the adj screw so to fit the fog light properly
we not have the info thanks 100, that the fog light (not housing) can be used for left or right so Red dog can now pick up this left hand reflector and make it a right hand and restore the fog lights on his roadster Done.
