Pull down on the right side (passenger side) when partially down continue pulling down and to the right so it will clear the plug on the left side of the light. A good replacement bulb is a 36 led 39mm bulb, way brighter than stock. These are polarity sensitive so turn it around if it doesn't work I had more trouble getting the lamp assembly back into position than getting it out.Here is a link under $4 for 2
https://www.ebay.com/itm/2pcs-39mm-C...t/391966549448
