Old Aug 20, 2006 | 03:28 PM
woody's Avatar
woody
Default Re: Today's Mistery Object
Originally Posted by 178
That's the battery vent tube that plugs into the neg side of the battery (upper top side you will see a small matching hole just match the hole to the plastic insert and push in) (point it down as gases vent into it and turn into a liquid were it is then stored to a point that simple removal and emptying keeps the battery acid from dripping down into the wires and engine compartment. Very important small piece thats needs to be put back to store battery acid.
The red cap is the positive side battery terminal protector snaps in two small holes on battery top to prevent accidental electrical contact.
178
I knew someone here would know! Thanks 178, I've replaced it in it's rightful place together with the terminal cap. Autoglass must have dislodged them when they did the screen.
Derek: good to hear you solved the riddle of the fuses! There is a beeper for the parking brake warning if you apply it on the move - perhaps the parking brake switch/wiring is shorting somewhere since after the gutting process. There is also a beep when manually retracting the spoiler, but I'm not sure why that come in to play.
