Old Aug 20, 2006 | 04:44 PM
HDDP's Avatar
HDDP
Default Re: Today's Mistery Object
Originally Posted by woody
There is a beeper for the parking brake warning if you apply it on the move - perhaps the parking brake switch/wiring is shorting somewhere since after the gutting process. There is also a beep when manually retracting the spoiler, but I'm not sure why that come in to play.
Don't know what it is... It happens occasionally during laps... Definitely not from TC since it happened at this point in the track. Definitely not RPM warning since I hit 5,000+ most of the time. Definitely not the wing since it is in the permanent up position and disconnected.
Listen carefully, you'll hear the repeated beep right before the chicane. Seems to happen as I lift from the throttle... I'm going to pull all the fuses from the systems that are no longer installed, before my next event, see if that gets rid of it...
http://www.hollywooddigitalimaging.c...BEEP_Part1.mov
