Old Aug 20, 2006 | 04:58 PM
woody's Avatar
woody
Default Re: Today's Mistery Object
Originally Posted by HDDP
Don't know what it is... It happens occasionally during laps... Definitely not from TC since it happened at this point in the track. Definitely not RPM warning since I hit 5000+ most of the time. Definitely not the wing since it is in the permanent up position and disconnected.
Listen carefully, you'll hear the repeated beep right before the chicane. Seems to happen as I lift from the throttle... I'm going to pull all the fuses from the systems that are no longer installed, before my next event, see if that gets rid of it...
http://www.hollywooddigitalimaging.c...BEEP_Part1.mov
Sounds like the parking brake warning - beep-beep-beep.
