Old Mar 16, 2019 | 11:26 AM
ala_xfire
Default Re: Valve cover gasket removal
That is the fuel delivery line, it is normally under pressure ( about 55 PSI ) but the quantity will be small if you loosen it without removing the pressure.
You can do it either way, as is ( with pressure ), or remove the fuel pump fuse from the RCM while running.
As you can see, the fuel pump fuse is the first blue one past the yellow one.
