Thread: Parting out
Old Mar 22, 2019 | 08:03 PM
zip439's Avatar
zip439
Default Re: Parting out
I'd like the plastic trim piece the passenger seat belt goes through. if you can get it off without breaking all the attachment tabs. It is between the bulkhead plastic and the small side window. It has Mercedes number 193 690 04 25 marked on it.
I would also like the small plastic caps that cover the windshield washer nuts holding the arm in place.
Under the car there are two bars which run from the rocker panels just below the doors forward towards the center of the car. They are attached with three bolts. I need one of those bolts. You will have to heat the bolt good before you remove it as it has lock-tight applied and will strip if not heated. They are easy to get at and removed once heat is applied.
I'll take the windshield surround trim also if that price is not too high.
Please send a private message, with prices and shipping to 36310 in Alabama. Paypal works for me.
