Thread: Lowering?
Old Mar 24, 2019 | 08:53 PM
DHS's Avatar
DHS
Default Re: Lowering?
NA on left ,stock SRT on right, NA has 345mm front disk.
NA or SRT? I went with the K&W springs they can be adjusted from 1” to 2” lower, the SRT is a little lower than the NA after my springs on a NA it is about a 1/2 inch lower than my SRT. Most of the other springs will lower to different heights. You need to look at each set and make a list, then decide how low you need. I got a rear camber bar off eBay, not hard to put on and will give a shop The ability fine tune the rear wheels. As for the front there are some washers that will reduce the front camber some, but this will be a fixed change. K-Mac makes some bushings for the front lower “A” arms that are adjustable, but these are more expensive and a bear to change out. You could change springs then go to really good shop and check on how much if any camber change you need, toe-in should be adjustable as is.
