Skreem and PCM
Just wanted to let others know that if your Crossfire’s Skreem goes out, (which also requires a new PCM), I learned from someone else on this forum, you can bypass the system by disconnecting the battery, and removing fuse #9. The mechanic said he had to let it cycle a few times after starting the first time. It runs great now! Removing fuse #9 takes out the map reading light and trunk light, and you have to use a key to unlock the car, but compared to paying over $4300 in repairs or junking the car, I think this fix is awesome!
