Old Mar 29, 2019 | 04:43 PM
EdwardB's Avatar
EdwardB
Default Re: Super charger issues.
" Clutch Hub that's mounted on Supercharger is Warped 0.05 - 0.010 and The Play between Bearing and Shaft." Per my mechanic
Also:
"the Clutch hub bearing and shaft have a lot of gap the Bearing Floats around the shaft before tightening the Front bolt and centering washer. Usually Bearing ID That's the Race when sliding over the shaft theres quit a bit resistance instead of nothing."
