Old Apr 4, 2019 | 12:58 AM
  #1236 (permalink)
BenzFire's Avatar
BenzFire
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
If it keeps cranking but doesn't start it's probably your crank sensor. After cranking a considerable amount of times ( about 9-12) without successfully starting the engine it should throw a check engine light with the faulty crank sensor code Check to see if you hear the buzzing noise from the fuel pump when you turn the key over to run right before cranking. If not, then it's your fuel pump (RCM ISSUE)
