Old Apr 4, 2019 | 08:38 AM
  #1238 (permalink)
Hijackd's Avatar
Hijackd
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by BenzFire
If it keeps cranking but doesn't start it's probably your crank sensor. After cranking a considerable amount of times ( about 9-12) without successfully starting the engine it should throw a check engine light with the faulty crank sensor code Check to see if you hear the buzzing noise from the fuel pump when you turn the key over to run right before cranking. If not, then it's your fuel pump (RCM ISSUE)
Looks as though I should do both for good measure. For the most part I can deal with the RCM repair on my own (assuming it's just the solder joints). Where might I find the crank sensor for a low cost?
