Re: C32 Brake upgrade
You need to look at #190 post you can see the caliper and 345 on the steel bridge that connects the two aluminum caps. It should have two "ears" that bolt to the hub, yours looks one solid piece for the bridge with the caps on each side. my photo of the parts being painted you can see the bridges you switch the caps to the other side to get the pucks small over big.
