Old Apr 7, 2019 | 11:07 AM
onehundred80
Default Re: Brake Light Problem...
Originally Posted by manlaw38
I have a question about the exterior lamp sensor being on all the time . What lamps fall under this sensor is it all lamps in car or just outter lamps like stop and running and headlights low and high beam, because I replaced the tag lamps back to the factor long tube bulbs took out the LED bulbs and the exterior lamp sensor stays on all the time while cart is running with lights on and off . Why would the yellow lamp on dash be on all the time while car is running ??? . This is next to the last light on the dash I need to fix other than the TPS warning lamp which is the easy part I am hoping is easy fix.
How about the marker lights in the top outer corner in each of the headlamp units?
Did the light suddenly appear or had you done something to the lights?
The dash indicator light just shows problems with the exterior bulbs.
