Update:
man this really sucks.. that’s my update.. kidding
called mechanic
1. He said he already pulled the battery cables off waiting 3 minutes then tried to start and he said it tried to start but barely then went back to not turning over but still have all lights, etc working
2. He said the code is P2071
3. I was reading on here about removing fuse #9 to get it to start. Should I ask him to do that?
any more advice? Feeling helpless. Need to figure out my car situation this week.
delighton
Thank you!!! In response to your comments plus some additional info. that may or may not help...
1. I don’t know what the mechanic did. I will call and ask.
2. I will also ask if he used a Scan tool and what codes came up.
3. I didn’t disconnect the battery cables before the tow truck driver came. I will ask mechanic if he did that.
4. Note that the headlights were flashing like the alarm was going off. The alarm button below the radio or on my key hadn’t been pressed.
5. I do not want to go to the dealer but where it is right now they are telling me I need a new alarm module and programming from the dealer but even the dealer doesn’t think I will. I was reading on this forum people just replaced the batteries in the alarm module. Couldn’t that just be the case?
6. When I turned the key all the lights would turn on, dash and exterior, and the air conditioning fan but it doesn’t start up. So no “rrrrmmmm....rmmmmm”, just turn, then complete silence other than the sound of the fan
Some questions maybe not necessary for now...
7. If it is a SKREEM issue then what? (will the DTC code tell me this)
8. If it is a RCM issue then what?will the DTC code tell me this)
Thanks Evette
