matabufalez
Hello,
Really, the car is not mine and I received it as a gift when it came broken. The car repair store said it was a clutch failure and budget about 1500 for repair it, so the owner after this 420.000Km got another car and give me the Xfire.All that km have been made on highway, so the mecanic parts are in a very good condition
The tail shaft looks quite good, It hasnīt damage on the splines. My worry is about the nut, I will tight to the torque (180Nm) and use loctite 243 to prevent another failure.
Glad the tail shaft is ok, was wondering by the splines on the 3 arm prop being messed up on both ends.
Before you put the prop back on, can you do me a favor and take a few pics of the tail shaft and splines .
When I was working on my single piece driveshaft I had some leads for yokes to bolt on, just never took off my props, just made some adapters to bolt on the props, and got a aluminum driveshaft with slip, cut down, rewelded and balanced.
Rare to have a nutt from a prop or yoke come loose, usually it is a pain to get it off.
