Speedy4x4
Glad the tail shaft is ok, was wondering by the splines on the 3 arm prop being messed up on both ends.
Before you put the prop back on, can you do me a favor and take a few pics of the tail shaft and splines .
When I was working on my single piece driveshaft I had some leads for yokes to bolt on, just never took off my props, just made some adapters to bolt on the props, and got a aluminum driveshaft with slip, cut down, rewelded and balanced.
Rare to have a nutt from a prop or yoke come loose, usually it is a pain to get it off.
Hello,
I didnīt plan disassembly the rear flange, so I canīt see the splines on it (I need a long 32-34 key). Here I give you some pics, I hope you can see it, here Iīve seen youīre talking about balanced driveshaft but I didnīt make any mark to the coupler (bad done?)
