Old Apr 19, 2019 | 08:10 AM
waldig's Avatar
waldig
Default Re: Way too much boost pressure. ..21 PSI
The crossover manifolds will increase the cylinder pressure as the filling is more complete, lowering the S/C back pressure. If the boost bothers you, you can just add restriction in the inlet path to the S/C, I would not worry about 21 # as long as the temps dont get too high on the air sensor. Woody
