Old Apr 20, 2019 | 01:11 PM
ncarusojr@comcast.net's Avatar
Default Key Fob Issues Lock & Unlock
So I’m having what I think is a unique problem. The key fob lock and unlock are not working. I’ve replaced the battery’s. I’ve tried disconnecting the battery. When I do that the key fob works to lock and unlock the car just fine. Then I try it again later and it doesn’t work. I’ve tried re syncing the fob with the car by double pressing one of the buttons and then turning the car on and that also works at first then also stops working later in the day. The car starts and unlocks fine with the key so I know it’s not the locking mechanism or the skeem. Any ideas on how to resolve this issue would be appreciated. We have only had the car a couple of weeks so I may not be up to speed on how to resolve this yet or what it might be causing the issue. When I re sync the fob inside the car the flashers blink twice then I insert key and turn to on position. Not sure if I’m just doing something wrong on the process of if something is faulty. Thanks for any help.
