Old Apr 22, 2019 | 05:56 AM
No2fast's Avatar
No2fast
Default Re: Way too much boost pressure. ..21 PSI
Ok. - As i thought - Manual mode only possible in "W" (holding gears). In "S" the software is not holding gears, downshifting as usual.
As far a i understood the TCU limiter is raised to 6700 but obviously the tune is not. Anyway. I agree, it doesn`t make too much sense to shift @ 6700 with a 62mm pulley. The SC is way out its efficiency.
Also i am afraid that the valve springs will not hold the pressure @ 21 psi @ 6700 for a long time ->. Valve floating.
Steven
Berlin Germany.
