Re: How To: Replace the Washer Reservoir / Tank / Bottle (with pics)
[QUOTE=Fjp3105;922606]Anyone have updates on the part as the two listed stores are of no luck!
Additionally while I was at the Jeep dealer I asked about the crossfire reservoir and when the rep looked up the part. She said there’s a note on this part that reads “if customer complains about leaking, do not attempt to change either washer fluid reservoir or washer filler neck. It will not fix the issue”
I found this to be rather absurd, any thoughts before I buy the party and pull things apart?
Thanks,
Fro[/QUOTE
i removed tank, repaired link, bottom seam, reinstalled link fixed, took about two hours, remove front tire, inside liner, tank, fixed
