Re: How To: Replace the Washer Reservoir / Tank / Bottle (with pics)
Remfire
Fjp3105
Anyone have updates on the part as the two listed stores are of no luck!
Additionally while I was at the Jeep dealer I asked about the crossfire reservoir and when the rep looked up the part. She said there’s a note on this part that reads “if customer complains about leaking, do not attempt to change either washer fluid reservoir or washer filler neck. It will not fix the issue”
I found this to be rather absurd, any thoughts before I buy the party and pull things apart?
Thanks,
Fro
i removed tank, repaired link, bottom seam, reinstalled link fixed, took about two hours, remove front tire, inside liner, tank, fixed
The reservoir does not fill past the top of the tank as it has an overflow there. The overflow lets the fluid fall to the ground. When the low washer fluid light comes on you can put in 4 litres anymore flows out the overflow.
