Old May 5, 2019 | 03:27 PM
onehundred80
Default Re: Valve cover gasket part numbers the same?
Originally Posted by Tom3120
I'm shopping for a set of valve cover gaskets for my 06 N/A roadster. Are the part numbers the same for the N/A motor and the SRT motor? I found part numbers of 05097104AA (left side) and 05097105AA (right side). I assume they are all made of the same material? I know I can get them from Needswings and I may, but I was just looking for confirmation that these were the correct part numbers and material type. I want to make sure the material type had not changed over the years or something silly like that.
I buy as little as possible using the Chrysler part number, even independent stores mark up the price, use the Mercedes SLK equivalent part and part numbers. Buy good quality items as it is not a job you want to do too often.
