Old May 8, 2019 | 09:44 AM
32er's Avatar
32er
Default Re: Boost testing on my crossover manifolds
I've read - the (stock) fuel pressure regulator tries to keep a constant over-pressure.
From which location becomes the fpr its information about pressure level (its a tube, so not the map-sensor-value!?) before or behind the (former) restriction (Y)?
If behind, the lower indicated map-boost at least works not "mechanically" against you.
