Thread: Pcm
Old May 10, 2019 | 03:40 PM
onehundred80
Default Re: Pcm
I doubt 20 minutes is long enough for the heat to soak into the module box.
If it is the CPS you have to buy a Bosch one, others do not seem to work at times because of a loose fitting plug.
What codes are set other than the one you mention?
