Re: Third Autocross of the Season
2018 Civic Type R's are quick. I have the same mods as you except I run the AMG front sway bar, KYB shocks and alternate between Federal RS-RR and Bridgestone RE71R. Evo school Friday. See if it helps. Considering moving up to next class with adjustable suspension and Vogtland springs. Pretty much running out of options to go faster. Also considering 2018 BRZ Limited with Performance package and Jackson Racing Supercharger. What tire pressures are you running for autox? I have been running 30psi front and 28psi rear with rear sway bar disconnected. Seems to rotate better.
